Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
Project 8: Replacing Spark Plugs
Got any questions on Project 8 for your E36 or E30? Ask them here!
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines
Coming in 2010:
101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your MINI Cooper (2010) • 101 Projects for Your Porsche 996 / 997 (2010)
Old 09-01-2006, 11:39 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
What is the spark plug gap on an 04 325XI supposed to be ..Thanks
Old 05-17-2008, 04:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Jeron's Avatar
AFAIK, all modern BMW's call for plug types that come pre-gapped. Those plugs are usually a bit expensive but they last 50-100k, so they are worth it.
For grins, I looked in Bentley and I didn't find a spec.
I suggest using a decent torque wrench for installation, 18ft/lbs.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l
Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
Old 05-18-2008, 09:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
bill_schuster's Avatar
Spark Plug Wire/Cap/Rotor Replacement
I'm doing some maintenance for the first time on my 1990 325is - Can anyone help me with some information re: replacing the spark plug wires?
I've referred to 101 Project (seems to capture the process for an E36) and the Bentley manual.
1) I having some difficulty (by looking) seeing what wire/connector comes off of the 2nd spark plug wire, where it goes, or the best way to route it through the engine compartment.
2) The Bentley manual also directs taking off the fan shroud and fan in order to get to the distributor cap and rotor. I was wondering if this is the best course or if it is merely a recommendation and can be performed with fan/shroud installed.
Does anyone have pictures for doing this project on an E30?
Old 08-18-2008, 09:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Pain
1. I think the wire you're referring to is the speed sensor. It snakes around in front of the engine and connects to a conector on a bracket under and behind the main harness diagnostic connector on the driver's side. If you have Bentley's look on page 2:5 (I'm not sure if they are all the same or not). The top right image shows the diagnostic connector (with an arrow) and the two wires are connected to a bracket under and behind. The path this wire takes makes it a pain to replace.
2. I didn't have to remove the shroud to replace the cap. It probably just makes it easier. You have to jiggle the cap a little and it's kind of a tight work area, but it can be done.
Terry
Account Manager, The Brickman Group LTD.
2008 Ranger (company car), 1999 Ranger 4.0 I6 (parts retriever), 1990 Bronco 5.0 V8 (camping and beach), 1991 325IX 2.5 I6 (kayak hauler and grocery getter).
Old 08-18-2008, 05:08 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Mercedes are ugly
BMW Roundel
Hi, everybody has their own rule of thumb when it comes to choosing spark plugs. Which ones do you choose for your bimmer? I have bosch platinum +4 on mine (5 spd 1991 318i)now, but I don´t notice much of a difference.
Old 08-25-2008, 07:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Jeron's Avatar
I've had several bad experiences with Bosch. I prefer NGK.
You wont notice anything with new plugs unless one of the old ones was seriously bad or damaged. Plugs are like oil, you change them on an interval and there is usually a lot of useful life left when they are replaced.
Old 08-26-2008, 05:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
I spoke with a technician at Bosch and he said that older cars do not have the features that the +4 plugs are designed to enhance. Go to the Bosch web site and there is a parts finder function and it will give you spark plugs and other parts for your car.
Old 08-27-2008, 08:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Jeron's Avatar
Let me amend that, I prefer NGK and single electrode.
Old 08-27-2008, 08:15 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
porsche1's Avatar
About Spark plug wires for 1988 325is?
what is the wire induction for? what number wire is this wire connect too?
Old 09-23-2008, 07:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
daryldaryl1
Grounding wires for the coils
Firstly, I must commend, the instructions and pictures for project 8 were great. Very easy to follow, and good pictures like these are hard to find. I'm not what you'd call a gear head so I appreciate the help.
As for the grounding wires that I found on my engine, the one on the right was missing and the left one was disconnected. I just left them as they were because I haven't had any problems but I hope to correct them later once I can replace the missing one. Can someone tell me what exactly they do?
Also, a bit off-subject, does anyone know where I can get a diagram of the engine labeling all the components? Sometimes I find some component or hose and cannot figure out what it is or what it does.
Thanks,
D
Old 10-04-2008, 09:11 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Jeron's Avatar
Most diagram sets require you to know something about the item you are looking for to find the correct diagram. Bentley Repair manuals have pretty good pictures and diagrams. Realoem.com has great diagrams.
Old 10-06-2008, 07:13 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
