CEO, Pelican Parts Inc.
Project 9: Replacing the Valve Cover Gasket
Got any questions on Project 9 for your E36 or E30? Ask them here!
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines Coming in 2010: 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your MINI Cooper (2010) • 101 Projects for Your Porsche 996 / 997 (2010) |
I understand that sealant should be put in the areas specified with a silver sealant which I'm assuming is the RTV. However, when I looked at the bonus pictures, there are some showing black sealant smoothed out on the valve cover. Is that the same sealant? Should sealant be put under the gasket and on the valve cover or just the valve cover?
Also, there is a photo (figure 22) showing a black tube removed from the right of the engine. What is it and is it necessary to remove it to remove the valve cover? Thanks |
Can you post a DIY Valve cover gasket for the 4 bangers? We change gaskets too!!
I just did this job, not bad but I used some rtv-silicon gasket kinda stuff instead of a gasket glue. It's gonna leak like a sieve isn't it? |
