CEO, Pelican Parts Inc.
Project 17: Head Gasket Replacement
Got any questions on Project 17 for your E36 or E30? Ask them here!
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines Coming in 2010: 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your MINI Cooper (2010) • 101 Projects for Your Porsche 996 / 997 (2010) |
When cleaning the pistons and gasket surface of the block what type of abrasive wheel did you use and did you use it on the piston only or the gasket surface as well?
Did you plug the coolant passages in the block to prevent debris from entering? Did you just use air to blow debris from the ring area or any other methods? Here is picture of the abrasive wheel you used: http://www.101projects.com/BMW/Projects/017/images/DSC00630.JPG Here is a link to the 3m website section on abrasive products. Choose "Surface Conditioning Abrasives": http://solutions.3m.com/wps/portal/3M/en_US/Manufacturing/Industry/Product-Catalog/Abrasives/
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
I used a mild "plastic" type wheel that I had around the shop. You don't want to put any deep scratches into the gasket surface - all you want to do is remove the old material. The plastic/rubber wheel is abrasive, and good at removing the old debris without damaging the steel surface. The head replacement went well with no leaks. If you don't get all of the material cleaned off, then you could get high spots and coolant leaks.
Yes, I used tape over the coolant passages, and then got around the holes with a razor blade. I used a vaccum cleaner to vacuum up the debris. I might have had an assistant hold the vacuum while doing the cleanup - can't recall exactly... Hope this helps, Wayne
I havent found a good selection of abrasive wheels yet. I've tried Hoem Depot and Northern Tool but the only wheel they sell is WAY to hard.
I'm going to try PepBoys and OReilly Auto next. Thanks.
Junior Member
I just replaced my head gaskets and now it is leaking oil out of the front corner of the head. Any ideas? It is a reman head.
Have a good one, MMTuning |
