CEO, Pelican Parts Inc.
Project 20: E30 Timing Belt Replacement
Got any questions on Project 20 for your E36 or E30? Ask them here!
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines Coming in 2010: 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your MINI Cooper (2010) • 101 Projects for Your Porsche 996 / 997 (2010) |
I need help with my timing belt issues with my 1991 325i sedan. I created a new thread this evening. All the background info is in there.
Essentially, i need to know the following: Right now, i don't know for sure if my timing belt is, in fact, broken. If so, is it at all possible that i didn't do major damage to the engine? I was in a turn and didnt have my foot on the accelerator. Essentially, the engine was at or near idle speed. any help is greatly appreciated. Thanks! matt |
If it broke or the belt teeth sheared off then, you more then likely damaged a few of the valves.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
Camshaft and crankshaft reset?
Hi Wayne,
On project 20, photo 8, skipped to photo 14 to replace the camshaft seals. In doing so i accidentally rotated the crankshaft pulley after the belt was off. After realizing this I manipulated the crank by attaching and readjusting the belt so that it and the camshaft sprocket would both line up at TDC. With both (crank and cam) lined up at TDC, and the belt on, the crank pulley will not rotate more than 100 degrees. Are there steps to reset? Maybe the crank needs to rotate another 360? Please advise. Thanks |
