Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
In memory of Warren Hall (Early S Man), 1950 - 2008.
[Click for more details]
banner
BMW Roundel 85 bmw 318i stuck in Reverse?
I have a 1985 bmw 318i and one day last week it was cold outside an i went to shift out of reverse an felt something slip, then it wouldnt come out the shifter is loose feeling so i thought probably the bushings so i start to remove driveshaft and saw that my shifter is laying down on the driveshaft so i'm hoping bushings but i got all of the bolts outta the driveshaft transmission output flange all 6 bolts and all of them at the rear diff and even took the aluminum shield and the center bearing down but i cant get the driveshaft to come off the transmission output flange so i can take it out to get a better look at the shifter problem. Any help would greatly be aprreciated. Thanks. Doug
Old 01-29-2012, 03:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Frajo's Avatar
Iʻm not sure I understood everything you were trying to explain. However if youʻre trying to remove the drive shaft, did you also remove the center bearing bolts? On my 88 325 I did not have to remove the entire drive shaft to access the shifter linkage... only the tranny output and center bearing. Do you have a Bentley manual or even 101 projects book?
Old 02-07-2012, 10:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
It isnt needed to remove the drive shaft to replace the shifter bushings. I does make it slightly easier however. You need to remove the bolts holding the center bearign to the chassis and also loosen the large nut on the driveshaft.
Old 02-09-2012, 07:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
