-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Timer on OBC (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/100616-timer-obc.html)
Jared at Pelican Parts 03-04-2003 10:42 AM
Timer on OBC
Anyone know the exact usuage of this thing? Like what use could it possibly have? Also I seem to be unable to reset the unit no matter what I do.
Javier at Pelican Parts 03-04-2003 03:03 PM
Its a count down for self-destruct....BOOOOM!!!!
Jared at Pelican Parts 03-04-2003 03:06 PM
the little unknown James Bond features of the car....
I want .50 caliber machine guns mounted behind the headlights as well as an oil sprayer at the rear.
Zoomy 03-04-2003 04:44 PM
Well,
I use mine for Time/Distance measuments.
i.e. Checking Speedo error.
Is this route quicker over another.......
Etc....
bertible 03-04-2003 09:19 PM
Seriously zoomy, can you actually set yours, or somehow get it to move? Like Jared, I've tried everything to reset it, or to get it to start counting, but it doesn't do a thing.
'bertible
mc30707 03-05-2003 03:25 AM
Mine works,
1)Press "timer" to go to timer
2)Press "set res" to start timer
3)Press "set res" a second time to stop the timer
Does anyone know how to change the clock from a 24 hour clock to a 12 hour clock? Also my outside temp button is in °C.
I understand how to read them in this manner, but a 12 hr clock & °F temp button wouild be preferable
thanks,SmileWavy
Jared at Pelican Parts 03-05-2003 10:23 AM
Nothing happens when I hit the set res button.
Bijan 03-05-2003 11:21 AM
While you push the little botton with a pen, you press AVE MPG button. That will switch it to Miles and Farenheit and 12 hour clock
Jared at Pelican Parts 03-05-2003 11:31 AM
yup, thats the way you reset it.
mc30707 03-05-2003 11:56 AM
Thanks guys, I now have a 12 hour clock and °F temp buttonSmileWavy
Jared at Pelican Parts 03-05-2003 12:51 PM
Ah the wonders of the Fahrenheit scale..
Does anyone know what the other miles per gallon feature is on the OBC? It has MPG, then another miles per gallon scale. Is this for what they call imperial gallons?
Zoomy 03-05-2003 02:43 PM
Here's another OBC trick...
Press the "1" and "1000" at the same time.
It will give you fuel remaining in liters.
You can not change it to read gal, sorry.
Jared at Pelican Parts 03-05-2003 03:14 PM
Canot change it to read gallons? That what mine currently reads. Am i missing something?
Zoomy 03-05-2003 10:10 PM
That's strange.
Others I's talked to say theirs reads liters.
Jared at Pelican Parts 03-06-2003 08:53 AM
Well, I just filled up my car this morning, and it read gallons. You can toggle between liters and gallons.
mc30707 03-06-2003 12:45 PM
Mine reads in liters. How do I toggle for gallons?
Jared at Pelican Parts 03-06-2003 12:46 PM
hit the button that shows MPG, then press the small button on the panel using a ink pen or other small sharp point, and it will toggle it.
Zoomy 03-06-2003 06:32 PM
Cool, Thanks, I'll try it. Better than using a fudge factor of 4 to figure gsl.
bertible 03-08-2003 10:51 AM
Just to clarify, the other measurement is liters per 100 kilometers. (not km per liter). Europeans use it, and us Canucks are supposed to use it. A lower measurement is better, indicating you are using less gas for the distance. However most Canadians think in mpg, but it imperial gallons which are about 5 US quarts.
My 87 uses around 10 liters per 100 km, which is about 28.5 miles per Imperial gallon, which is about 23 miles per US gallon. (very rough conversions)
So in the US, does the small fuel economy gauge below the speedo show in mpg? (up here it is in liter per 100 km)
Gary
87 ' bertible
Vancouver BC
gmny 03-10-2003 05:03 PM
Also, while playing around with the OBC this weekend, I found that if you push either the AVG MPG or AVG MPH buttons, and then hit SET RES it will give you ACTUAL miles per gallon and ACTUAL miles per hour on the fly as your driving.........FYI, just some usless trivia!
Greg H.
