-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   E36 Brake Question (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/1007746-e36-brake-question.html)
prariepilot 09-13-2018 01:30 PM
E36 Brake Question
I've upgraded the brakes on my 1999 318ti M44 to drilled and slotted disks and ceramic brake pads. Now, there is a very low speed "abs chatter" that occurs below five mph regardless of how hard the braking is from speed. I can be running sixty and step on the brake - not hard, but firm. The "chatter doesn't start until I'm almost completely stopped.
Is there a "left" and "right" designated rotor when using slotted and drilled disks? Might this be causing the "chatter" if installed backwards? I'm not getting any codes from the OBDII, so I don't suspect a wheel speed sensor. Thanks for any suggestions.
