BMW Roundel e34 m5 high rpm clutch vibes
Recently had a new sachs clutch and pressure plate installed. the shop did the rear main seal, throw out bearing, engine mounts, transmission mounts, pilot bearing, stainless steel clutch line, pretty much everything you are supposed to do on a clutch install.
the problem: all runs perfect except that when you depress the clutch at anything over 4k rpms, switching gears or simply revving in neutral (not that i rev in neutral other than to elicit the noise) there is a loud whirring noise and a worrying vibration coming through the clutch pedal. it increases with engine speed. at redline it sounds very spooky.
the shop thinks that Sachs sent me a defective throw out bearing, which I find highly unlikely. before the clutch was changed there were no sounds or issues whatsoever, simply a soft engagement. please let me know what you all think, thank you.
harry
Old 10-17-2018, 08:35 AM
