What part is this
Can some one tell me exactly what part this is"Picture of Part" I thought it was the idle control valve but i think i might be wrong.
Also if my 318is was made on 11/95 will it be a M42 or a M44. I thought it was a M44 as it was made on 11/95 therefore its a 96 BMW but then i found out that the M44 came with ODB II but i think my car has ODB I because i can check my fault codes using the pedal system. I need to order some parts but now im confused. Thanks |
What part of the engine did the part come from?
Is there a part # on the part? It looks like a vacuum regulator check valve, but it's hard to tell from that picture without more of a description. |
Here is another picture of the part inside the car, it is in a vertical position so its harder to spot but i have put a blue circle around it. Two hoses connect to the part one on the top the second on the bottom. There is also an electrical connector.
"part in car" |
That called a fuel tank vent valve, about $55.00. e-mail me
javier@pelicanparts.com I'll give you more info. or call 1888-280-7799 ex239. |
Javier you got mail. Any info on the M42 M44 issue.
| All times are GMT -8. The time now is 04:12 AM. |
