Silver89ix's Avatar
Send a message via AIM to Silver89ix
'95 325ic central locking problem
The central locking system doesn't work from the drivers door but works from the pass. door. The lock works but will not lock/unlock the other door or enable/disable the ignition cut-out.
Any ideas where to start looking.
Bob
1989 325ix
1995 325ic
Old 03-31-2003, 07:54 PM
same problem
I was told to look at the harness that bends so frequently in the door hinge.
do tell what you find
Old 03-31-2003, 08:38 PM
Senior Advisor
Javier at Pelican Parts's Avatar
Sometimes the rod that connects to the back of the lock cylnder then to the actuator pops out, this could be the cause, the cheap one, although could also have faulty actuater, remove door panel and inspect. I used to have this problem with my E28 it was the rod.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 04-01-2003, 11:57 AM
Mine comes and goes every 3-4 weeks, it is definately electrical.
What happens when you depress the lock manually? Does it electronically assist you by "snapping" into place like the other sides do ... or does it just not work at all?
Old 04-01-2003, 01:28 PM
