Ok, a few more bragging rights
If Anyone would like info on painting your car for about $150 and have it turn out like this, email me for info.
Old 04-06-2003, 11:47 PM
Wayne....
Ok...heres the scenario.
Ya gotta start off with a well prepped surface..(of course).
My 914 started out with having the "wide body" rear flares and some Rube Godberg nonsense done to the fronts via a hammer....so I purchased some 914 GT style front fiberglass units & riveted them on and faired all 4 flares into the body.
The rear spoiler was an "adapt" from a 80's IROC Camaro and it was also faired into the trunk lid.
Ahhh..time for paint!
Ive painted cars in the past with real laquer with a gun but those days are gone thanks to the EPA requirements for low VOC emissions.,so, I looked high & low & found Rust-O-Leums "laquer" in a can on the shelf at Home Depot at $3.79 a can.
I purschased one can & thought Id just test it on one fender...and the results were Astonishing!!...heres the procedure:
1. Apply approximately 4 coats with each other coat sprayed at opposite or criss cross styly applications.
2. Color sand lightly with 800 wet o dry paper just to dull up the surface.
3. Apply 3 - 4 more coats in same fashion, emphasizing a litle more paint on the raduis corners or edges of vehicle.
Note:....theres no secret here to spraying technique, & after the first can & a few small runs, youll develop your own technique for a good surface application.
4. Let the car dry for approx. 4 days
5. Colr sand all surfaces again with 800 grit wet o dry in a wet environment.
6. Using a orbital polisher / sander and a terrycloth pad, cut all surfaces with a good cutting compound....youll have to experiment a bit but your trying to get a "dull mirrored" finish...be carefull of the polisher on corners as not to burn them.
7. Finally, and again with polisher, wax all surfaces and use a nice soft buffing pad.......you wont believe what a differnce will take place from that dull mirrored surface to the final product.
,..............Unfortunatley, Rustoleum only makes 3 colors in laquer..white, black and a forest green......but!...Pep Boys carrrys a line of laquer that offers 3 more colors i.e. silver, etc.....Ive tested both & theyre both good.
Hope this answers any questions..... its not rocket science, just a lot of work.
Dave.
Old 04-07-2003, 02:41 PM
hey wayne:
what are you going to do with a 908 engine?
I may know someone in the bay area that can
help you. He does a lot of Porsche race car
restorations.
jeff
Old 04-07-2003, 04:08 PM
