KUTCH's Avatar
Question More Clutch Questions
If, YOU where "getting close" to needing a clutch job in a 98 328is...
1. Would it be worth getting a higher performance clutch set?
2. Can you substitue an M3 clutch set? is it worth it?
3. What about throwing in a lightwieght flywheel? I thought I read you would need to change out the programming? does it really effect the engine that much to have that less mass?
thanks for any input!
Old 04-07-2003, 09:23 AM
