Ya know, I've always wondered why I can't use my front defroster without it being at full blast.
Say for example, I've got the heater running at the lowest fan setting & the windows start to fog. As soon as I pop on the defroster button, the fan increases to it's fullest setting. Then if I try to reduce the fan speed, the defroster goes off. Am I missing something, or is this how BMW intended the unit to work? It kinda seems dumb that you couldn't have the defroster on at a lower setting.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
914 Geek
Actually, that is the max defroster button. The "get it gone right now" button.
There is another button in the climate control that directs air upward toward the windshield. I believe it's over on the left side of the climate controls, along with the buttons for the floor and the dash outlets. This, I believe, uses whatever air is available from the fan and directs (some of) it up toward the windshield. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
