Unhappy Emissions failure
For a 91 325 I manual transmission.
Failed NJ emission for HC-195 vs Std of 124 &
Nox-1942 vs Std of 937
Gave a complete tuneup including timing belt, tensioner, wiring harness,cap,rotor, plugs,air,fuel,and oil filter, and changed the oil and retested the car,
Sensors checked out ok.
Failed retest for HC - 164 vs Std of 124
Nox- 2091 vs Std of 937
and CO - 72 vs Std of 66
Suggestions??
Old 05-14-2003, 03:19 PM
Lorenfb's Avatar
Your cat may need replacing since numbers are close to pass.
This is confirmed since the NOX is so high and far out.
Good luck
Lorenfb@aol.com
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-22-2003, 10:57 PM
Old 05-23-2003, 01:54 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Have you confirmed that the O2 sensor is indeed bad?
Old 05-23-2003, 02:03 PM
