Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Junior Member
Reprogram radio
I have the bmw 325i convertable and it has a 6 cd changer. Someone said i can re program it does any one know how?
Old 04-19-2003, 01:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Senior Advisor
Javier at Pelican Parts's Avatar
Re-program to what? I dont get the question.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 04-21-2003, 12:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Junior Member
reprogram the code it wont work cuz i need a code for it.
Old 04-21-2003, 01:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Senior Advisor
Oh yea, pull the radio out get sereil number off back housing. call your local dealer tell them you just changed the battery and radio went to code... they will get you the code. and then re=install the radio and type in the numbers.....
Old 04-21-2003, 01:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
supertack's Avatar
I've also gotten the code by calling the dealer with the vin #. Pulling out the unit could be a hassle because of needing that special driver & all.
Speaking of that special driver, has anyone had any luck removing the unit with an allen wrench or something besides that tool offered from BMW?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 04-22-2003, 03:29 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Senior Advisor
Super..I think ther maybe in error in your last statment, the dealer can not supply the code from the vin as these units are anti theft units and are not specific to the vehicle during production....
they are installed randomly with code cards in the owners manual...
but then again.....see my sig....
Old 04-22-2003, 09:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
I believe that if you can prove to the dealer that you are the registered owner, they will provide you with the codes.
Old 04-22-2003, 10:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Senior Advisor
You are correct in that Jared, but not with the vin.. you will ahve to supply the radio sereil number off the back..usually if you go strate to the parts department they will get it for you takes about 5minutes through their DCS sysytem...
if you dont have the tool to remove it a decent dealer service dept will do it for you.....
Old 04-22-2003, 10:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
I've done the job with an allen wrench - but I believe I had to take a dremel to it and shape it down just a bit.
Old 04-22-2003, 10:47 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
I believe it is a 2.5mm allen head that you need.
Old 04-22-2003, 10:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
supertack's Avatar
No disrespect Javier, but in my case you are wrong. When my battery 'bit the dust' last December, I found myself with the 'code' display. Now I bought the car from an import dealer, but it wasn't an authorized BMW dealership, & those geniuses gave me a code which had a '7' & a '9' in it. Well, as you know, the buttons on the unit only go up to '6'. So after I kicked **** around in my garage for a while, I called the German Car mechanic that I'd been using for a while. Since he'd done all the work on my Volvo 760 intercooler turbo that I replaced with my bimmer, he knew who I was & had personal records. He hadn't worked on my bimmer yet, so there was no way for him to know the serial number on the unit. But he called the dealership for me with the vin # which I gave to him, & got the correct code. I dunno, maybe there are limited codes based on model, year, & vin #, but it all ended well for me.
97 328is
Old 04-22-2003, 10:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Junior Member
guys i have the vin and the radio number but the epople arent there can i do this on line any where or can i call liek a delarship in california but i live in jersey. the serial code for the radio is f30760828A and there was a sticker on it with awa9865 any help please. i need this fixed by tonight thank you
Old 04-22-2003, 12:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Senior Advisor
Sterling, I ve got your code...but I dont want to post it call me
1-888-280-7799 ext 239
its toll free
I'll be here till 4pm Cali time....
Old 04-22-2003, 02:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Junior Member
GUys i got the code it works. Now i turn on the radio. The 6 cd changer dfoesnt work. How do i get that to work. ANd when i put down the windoews top or wutever turn on the lights. The radio shuts down to one speaker. IM guessing this is the alterntaor. am i correct?
Old 04-22-2003, 02:57 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Why would you think this is the alternator?
Old 04-22-2003, 03:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
supertack's Avatar
What an electrical nighmare Sterlingsxe, I feel for ya dude.
97 328is
Old 04-22-2003, 04:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
Junior Member
cuz i dont think the output on the alternator is enough to supply everything like when i step on my breakes it sometimes dies out. Im guessing its not putting out what its supposed two. I will probably do a draw test.but any other idea on what this could be. And its manual and when i have it in neutral and i put a load on like the top comming down or summin it almost sounds like its gonna stall. well its not my car its my gf im just trying to be a good boy friend. LoL VIVA LA CAMARO !!! lol z28 for life
Old 04-22-2003, 07:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
