-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   how do I remove my front rotors? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/108437-how-do-i-remove-my-front-rotors.html)
champeny 04-28-2003 05:05 PM
I want to do a front brake job on my 95 325i and replace the discs. Is there an easy technique to removing the discs?
champeny 04-28-2003 08:27 PM
Well, didn't have time to wait since I was in the process. Figured it out easy enough.
After removing the calipers, there is a single bolt that holds the rotor to the hub. An allen wrench will do the trick. There is also a hub cap covering that deceptively seems to want to be removed. Don't bother.
The rotors may be locked on pretty tight, so you may need to get friendly with a hammer or crowbar and give a few smacks before the rotor comes loose.
After that, reassembly is a piece of cake. And if you have a buddy close by to help you bleed your breaks, you're in good shape.
Jared at Pelican Parts 04-29-2003 08:35 AM
champ,
usually, you dont have to bleed the brakes when changing the brakes. All you have to do is compress the piston back into the caliper with a large C clamp..
champeny 04-29-2003 12:43 PM
yeah. I did compress the caliper pistion with a c-clamp, and the brakes still seemed pretty stiff - no air - but wanted to flush out the old fluid.
thanks
