relay chart
do anybody know where i can find a chart that says what relays do what?
In the shop at Pelican
Have you looked in the owner's manual? There should be a charrt in there.
i don't have one
Senior Advisor
I think the cover for the relay box has a lay out of which is what.
...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper... |
What in particular are you trying to find out? I can go look at Eli's E36, and get the fuse info off that.
is there such a thing as a comfort control relay? or what controls the power windows?
What is your problem?
the driver side window doesn't work
Does the window move at all or is it just dead in the water? Frist check to see if any fuses are blown and then check the comfgort relay.
ok thanks
