OBC brake error
Need a little help here. My brake light warning on OBC keeps coming on. To date I have replaced brake lighting assembly and pedal switch. Help, very frustrating predicament......
This may be a stupid question, but have you checked the pads? Uhh, or is that a different light?
--DD |
OK, first,
What year and model? Second, get under the car and actually check the pads. Usualy, when the light goes off, it means you have about 2-3K miles left before the pads start cutting into the rotors. |
Will give pads a look at later 2day and let u all know. Thanks for help.
What is the exact message? Does it read, "Brake Circuit Error"? If so, thats a common problem and I have the article that details the fix for it.
| All times are GMT -8. The time now is 12:54 AM. |
