Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Send a message via AIM to dakarm34
91 318is running rich, rough idle
I just bought a 91 318is with 85k miles. The car was running great when all of the sudden after filling it up with fuel it seemed to have lost a cylinder. Here's what I've done. If you have any ideas please let me know.
- all cylinders have 180psi
- new factory plugs installed
- new afm installed
- computer gave a code 29 - air flow meter
- car runs but runs rich
Do you guys think my fuel pressure regulator has gone out?
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 02:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
I've also put a new fuel filter on it and replaced all iac hoses.
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 02:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
Have you checked your coil packs?
Old 05-01-2003, 02:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Yeah, I did a resistance check on each one, and the resistance on all were the same. I pulled the plugs and put them on the valve cover and they were all firing.
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 03:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Ok, the code says AFm, did you replace the AFM before or after you got the code?
Old 05-01-2003, 03:10 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
I replaced the afm after the code was gotten.
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 03:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Hmm,...
Have you confirmed that the car indeed is no9t running on one cylinder? If the car is running rich, i would be inclined to check operation of the O2 sensor. It is wquite possible that it may be malfuctioning. I wouldnt suspect the fuel pressure regulator just yet.
Old 05-01-2003, 03:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
I didn't suspect the o2 sensor as I didn't get an o2 sensor code, just the afm sensor. I'll read up on how to test it and see if it's gone south, I thought that the car would just get poor gas mileage, not act like it's lost a cylinder. It runs rough, and sure does seem to have lost a cylinder. When I pull the plugs they are all wet, not moist, doused in gas.
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 03:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
So basically it is either a fuel or ignition problem. Have you checked that the position sensor on the front of the engine is connected?
Old 05-01-2003, 03:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
yes it's connected. How do you suggest checking to see if it's running on all cylinders? I may have a plug wire jumping
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 04:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Since I put new plugs in I pulled them to see what they looked like. cylinder 4 was still new, it hadn't fired. To determine if the coil for #4 was bad I swapped it with #3 and #4's plug then fired, plug was dirty. So I've got a bad plug wire for #4. I'm going out there to rig a wire to see if I can get them all to fire. I'll be ordering a set of wires from you guys. Do you recommend the bosch or pvl? Are the pvl's the correct length? That drives me crazy when I've got extra plug wire. THANKS AGAIN!
Rich
98 e36 M3/4
91 e30 318iS
87 e30 325iS
Old 05-01-2003, 05:04 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Go with OEM wires. That would be Bosch.
Old 05-02-2003, 11:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
