does anyone know how?
i've had my car close to a year now and i still haven't programed in the time and date in the obc. i don't have a owners manual so i don't know how. does anyone know how to program the time and date?
Old 11-15-2003, 09:37 AM
If I remember correctly: Hold down the time (or date) key until the display changes, then use the 1000/100/10/1 keys to change the it. When done press the set button. I'm assuming your car is the same as your member name?
Old 11-15-2003, 10:46 AM
blkongry's Avatar
Yep, that's the way the OBC works on my '94. Although, I had a hard time switching between AM/PM when setting the hour... I just waited till the afternoon to set the time since it was stuck in PM mode.
Old 11-15-2003, 02:03 PM
Author of "101 Projects"
Wayne 962's Avatar
Ha, funny. It took me about 10 minutes to figure this out (and I have two degrees from MIT). Dang, those German guys need to learn a thing or two about designing for usability.
To switch from AM/PM, simply keep advancing the hours - it should change...
-Wayne
P.S. This technique doesn't work on my 318 for some reason - I think the computer is either busted or confused...
Old 11-15-2003, 02:08 PM
supertack's Avatar
We switched from Daylight Savings Time to Standard Time not long ago, & it still took me a couple days to figure out how to change the time, 2 years after I bought the thing! I gotta commend them on the engine & appointments, but for ease & functionality, they get a frickin 'F'.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 11-15-2003, 03:01 PM
Wayne 962's Avatar
How about the door lock dance. Right hand all the way over so you stuff your arm in your mouth to lock the doors.
Or the roll-both-windows-down-at-the-same-time 8 inch finger stretch which single handedly gives me pulled tendons!
What else, hmm, the little 'M' button on the automatic transmissions that starts you off in 2nd gear at a light (read: no power).
What else?
-Wayne
Old 11-15-2003, 03:28 PM
i thought you had to hold set and time or date. and the hit the degree button
Old 11-15-2003, 07:28 PM
thanks, i'll try that
Old 11-16-2003, 06:45 PM
which button is the degree button?
Old 11-16-2003, 09:49 PM
stupenal's Avatar
What else?
-Wayne
I do the dance a bit differently, i use my left as i stretch backwards to hit it with my elbow. Much easier than eating your right arm.
As for the 8 inch finger stretch, i do a quick auto down on the drivers side and then dedicate the full hand to the passenger side. But yes, much complicated stuff in these cars.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 11-16-2003, 11:00 PM
