HELP!!! error code 42? Help Please!!
Just did an M50 swap in my E30 and getting no signal to the fuel injectors or the fuel pump relay. I am lost thinking that I got a bad ECU. The code reader is giving me out code 42 and I don't have the book to look it up. Thanks for your help.
Are you using an M50 ECU or an M20 ECU?
Have you checked all the gorund points? Did you also check the DME? |
ECU
I had an m50 ecu from a late 95 series. this was when they started putting the chips in the keys. so i got a 94 ecu and everything has worked great since. thx
Which Code Reader? The Peake tool? I've been meaning to scan this manual and place it online...
-Wayne |
| All times are GMT -8. The time now is 02:38 AM. |
