-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Is this a common problem? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/115095-common-problem.html)
matthew-m 06-16-2003 10:33 AM
I just found out that the secondary air pump has failed 13 months after I replaced it.:mad: I was told that water had somehow gotten inside from the hose that leads from the front (near the headlight) and seized it. This also happened the first time I replaced it. Has this happened to anyone else, and how did you go about fixing it? I would prefer to only replace this every 5 years, not every year! Thanks in advance for the help:)
