troubleshooting?? cold (only) start problem on '89 325i
hi,
i'm looking for a little insight before i order the wrong part ..... i've got a '89 bmw 325i, 139K, great maintenance ... everything runs beautifully ..... except on cold start if the engine is "good and cold", a typical ignition start (i.e., 1-2 second turn over) results in the engine dying out, requiring a subsequent lengthy ignition start, acting like its 'flooded', with an eventual 'catch' after an occassional rich 'cloud' from the exhaust .... if, however, that FIRST start is held longer, i.e. a couple of turn-overs for 3-5 seconds, the engine ususally catches and then everything is fine ..... when warm, no problems starting ..... perusing the 'boards', i've gathered that the problem might relate to any/all of: O2 sensor cam position sensor valve adjustment ... anyone have any suggestions as to how to narrow down my options and actually identify the problem? could it be something else? possibly relevant upgrades include: Dinan chip Malpassi Adjustable Rising Rate Fuel Pressure Regulator K&F Cold Air Intake Filter Cone Canton/Mecca cartridge oil filter Bosch Platinum+4 plugs RedLine fluids Optima Yellow-top Deep Discharge Battery K&F cartridge fuel-filter BavAuto High-Perf Ignition Wire Set thanks! richard |
| All times are GMT -8. The time now is 01:48 AM. |
