supertack's Avatar
Climate Conrol Question
How come when the windshield defroster is on, the fan blows at full blast? I've tried pretty much every configuration of fan/temp/defrost settings, but when the defrost button is engaged, the fan automatically come on full, & if you try to manually turn down the fan, the defroster goes off? I don't understand this, why wouldn't you be able to defrost at lower settings as you can with heat/ac?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 09-29-2003, 04:56 AM
don't understand? when you hit the defrost "solo" button over on the side with the AC picture of the snowflake -mine goes on full blast like yours. but when i'm travelling for a trip, i increase the cabin temp on both sides and self=select one of the three manual selections on the left side of the console (instead of the AUTO function). In this case only the "air up" button rather than on the floor or in my face. finally I increase the fan to high and de-select the recirculation if it was on (fresh air defrosts better)
thoughts?
97 328is
Old 09-29-2003, 11:06 AM
supertack's Avatar
Hmm, I guess that makes sense. What's confusing is, if the 'air up' button is intended as a defroster, then why doesn't it have the defrost icon. By the same rational, why would the 'solo' defrost button only be applicable only at full blast? I think we're missing something here.
97 328is
Old 09-30-2003, 04:22 AM
The "air up" button isn't a defroster necessarily. The defroster button (over the A/C) is meant to quickly defrost the winshield. It automatically turns on the A/C or heat if needed. After about 10-20 minutes it shuts itself off. It will not restart when the car is restarted (if I remember correctly it goes back to the last setting). When the control is "Auto" air is sent to the windshield, middle and foot vents simultaneously. You can also manually select were the air is sent at what ever speed by selecting the buttons on the left (including all 3) and you can use A/C, recirculate and whatever combination you see fit to make yourself comfortable. I hope that makes sense?
Old 09-30-2003, 07:32 PM
