Send a message via AIM to Benedetto
1988 325.... Distributor cap??
Hello All, new to the forum... I need to change my distributor cap and plug wires... Any tips on getting the cap off? It looks a little tight between the cap and the radiator.....
Thanks!
Old 10-29-2003, 10:34 AM
camaroman's Avatar
Use an 8mm socket with a small 1/4-inch drive ratchet. It's tight, but it works. I just changed mine.
Mike
Old 11-10-2003, 07:36 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Also, you will get new bolts with a new distributor cap. The rotor is also held on by 8mm bolts. Be sure to also transfer the impulse wire from the crank onto the new spark plug wire
Old 11-11-2003, 08:30 AM
