Hi guys,it's been a while ....i got i huge problem with my brake lights
....they don't work ....,i checked the fuse and it's ok ....what can it be then ?,i also checked the light bulbs they are also ok,is there something else to this that i don't know about ?,maybe a solenoid or something like that ?Thank you and please help me. Dan
Well,that's me and i can't help it ! |
Did you check the brake pedal switch? It may have died. I haven't looked for mine on my car, but it should be right behind the brake pedal (High up on the pedal arm). It may be out of adjustment or internally failing. Always check the easy stuff first.
No i havent,i didn't know there was one...so you're saying that there is a switch right under the brake pedal ?
Thank you Dan
Author of "101 Projects"
Yes there is. Let me see if I have a pic...
I have a tech article coming soon... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thank you "blkongry" and "Wayne at Pelican",you guys were right on,it was the brake switch....i changed it and everything is back to normal now,boy do i love my BMW when everything is 100%.I was surprised to see that the switch was actually very inexpensive,at only $ 23 canadian it was a big surprise.
I apreciate the picture and my appologies for taking so long to repost,if i can help anyone with anything i would love to repay the favor,i apreciate your guys help very much. Thank you again. Dan
One other thing,on my car the switch actually there was 4 prongs rather than two,ironiclly enough the 4 prong brake switch is acually $ 3 cheaper !,go figure....and to remove the thing you have to pull back the RED part fit in the switch and then push back the red plastic,i learned this the hard way.
Thank you all. Dan
Anytime, my friend.... glad to hear it was a relatively inexpensive fix.
Cool deal - glad to be of help. Repay the favor by telling all your BMW friends about this board, and Pelican!
-Wayne
I sure will Wayne,this is indeed a very knowlegeble forum.
Again thank you all. Dan
-Wayne
