does anyone know how?
i've had my car close to a year now and i still haven't programed in the time and date in the obc. i don't have a owners manual so i don't know how. does anyone know how to program the time and date?
If I remember correctly: Hold down the time (or date) key until the display changes, then use the 1000/100/10/1 keys to change the it. When done press the set button. I'm assuming your car is the same as your member name?
Yep, that's the way the OBC works on my '94. Although, I had a hard time switching between AM/PM when setting the hour... I just waited till the afternoon to set the time since it was stuck in PM mode.
Author of "101 Projects"
Ha, funny. It took me about 10 minutes to figure this out (and I have two degrees from MIT). Dang, those German guys need to learn a thing or two about designing for usability.
To switch from AM/PM, simply keep advancing the hours - it should change... -Wayne P.S. This technique doesn't work on my 318 for some reason - I think the computer is either busted or confused...
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
We switched from Daylight Savings Time to Standard Time not long ago, & it still took me a couple days to figure out how to change the time, 2 years after I bought the thing! I gotta commend them on the engine & appointments, but for ease & functionality, they get a frickin 'F'.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler Last edited by supertack; 11-15-2003 at 03:03 PM.. |
How about the door lock dance. Right hand all the way over so you stuff your arm in your mouth to lock the doors.
Or the roll-both-windows-down-at-the-same-time 8 inch finger stretch which single handedly gives me pulled tendons! What else, hmm, the little 'M' button on the automatic transmissions that starts you off in 2nd gear at a light (read: no power). What else? -Wayne
i thought you had to hold set and time or date. and the hit the degree button
thanks, i'll try that
which button is the degree button?
As for the 8 inch finger stretch, i do a quick auto down on the drivers side and then dedicate the full hand to the passenger side. But yes, much complicated stuff in these cars.
1997 M3 Sedan 5spd Artic Silver/Dove M3 Bumpers/Mirrors/Sideskirts S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes Oh wait...it's a stock M3 |
You'd think that they would have done some usability studies. But then again, have you ever met anyone German - they are kindof set in their ways...
![]() -Wayne
