-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   idle problem (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/138336-idle-problem.html)
mikescars 12-04-2003 02:09 PM
idle problem
Hello, my 85 325E is blowing fuse #9 frequently, I have run diagnostics on all related sensors and wiring, installed spare ECU , cleaned out idle valve on engine, and adjusted the TPS. all check fine.
the idle is running about 2500 rpm until I replace the fuse, then back to normal. standing alone at idle it will run for about 4 minutes until the fuse blows, or about 30 sec. if driving. Please help.
Mike
mikescars 12-05-2003 01:05 PM
ok, replaced the o2 HEGO relay, seems to have worked. Checked wiring dia. from dealer as Bently doesnt have fuel sys diag.
Jared at Pelican Parts 12-05-2003 03:42 PM
I was going to post that you should try replacing the relay, but looks like you figured it out before I could post.
mikescars 12-06-2003 08:28 AM
Yes, when looking at the diagram from bmw of Ann Arbor, i realized that on ly adirect short / load over 15a could blow the fuse, so checked all direct loads on that circuit. ( elect. 101 ) i believe.
mikescars 12-08-2003 07:19 PM
Surging problem now, 2days fine, weather is about 30-40 deg F. I thing something may be overloading a relay?? is this possible?
mikescars 12-11-2003 07:50 PM
This sounds weird, but today I unplugged the O2 sensor, no more problem......idle is fine except a little rough from rich condition. possibly a bad replacement sensor? it was bosch 3 wire universal type.
Jared at Pelican Parts 12-12-2003 08:31 AM
I have heard of rare cases where a bad o2 sensor can cause a bad idle...
