cjsdad1's Avatar
e 36 control arm bushing
Hi
I am at a loss. I replaced both front control arms and had a tool made to press the control arm bushing in to the housing(being careful to align the marks.
I went to the dealer today to buy the special lube part #
81 22 9 407 284 and was informed this has been discontinued with no new part #.
How do I get the bushings on the control arm, and on the ground in 30 min.
The control arms are installed on the car.
Thank you
Mike
Old 12-10-2003, 04:31 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Use dishwasher soap and water, I did and had no problems pushing the mounts on
Old 12-10-2003, 04:33 PM
cjsdad1's Avatar
Thank you
That will "lock the bushing on "?
Old 12-10-2003, 04:35 PM
You dont need to lock the bushing on. As long as it is in the relative position to the metal mount, it should be fine.
Old 12-10-2003, 04:36 PM
cjsdad1's Avatar
How does that bushing affect the wheel? I guess why is it there?
Old 12-10-2003, 04:48 PM
cjsdad1's Avatar
Hey that worked !
Do I need am alignment?
The manual said to measure the distance from the edge of the bushing to the edge of the control arm.
I did this and set them however they seem to have center them selves. Is thios a problem?
Mike
Old 12-10-2003, 08:08 PM
