-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   318i acceleration/idle problem (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/139828-318i-acceleration-idle-problem.html)
jjskibinski 12-15-2003 03:24 PM
ok, changed ignition control unit , problem now seems to be with acceleration. Bimmer starts fine idles at 850 rpm and is very steady at idle. Only a slight touch to the accelerator and rpm goes up then fluctutes and cycles aprrox. 800 rpm drop then back up to former rpm then back down again. after about 5 seconds of this, rpm reaches another stable rpm, example 2,200 rpm. upon slightly increasing rpm with accelerator depression the same cycling occurs. Thanks for any help.
Jan
