Talking 17" Wheel with suspension kit
Hey all. I just bought a 88 BMW 325 that is my new project However, I have some questions if any of you may or may not know the answer to. I am planning to put a SPAX suspension kit on it, that will drop it 1.5 in the front and rear, with 17inch 4-100 38m offset wheels. Does anyone have information on if these are good, or if I could lower the car more, without any rubbing, and is the offset on the wheels correct?
Old 01-12-2004, 05:53 AM
Jon325i's Avatar
You failed to mention the width of these 17" wheels you want. If its 7.5" or 8" wide, you will want to have a ET20 offset which means you will need 18mm thick spacers to make it work. This will allow you to run a 205 or 215 width 40 series tire (depending on manufacturer since some tires have a wider mid-section than others). You might be able to do a 225 width 40 series tire but it would be very close.....rolling your fenders should be considered mandatory.
Jon
Old 01-12-2004, 10:52 AM
