Roundel Guy's Avatar
Send a message via AIM to Roundel Guy
Question How do I test for Clean Power Supply?
I have been some electrical problems, and I (not surprisingly) can't quite put my finger on the source (see my old post "aggravating electrical problems"), so I decided to turn to y'all for help. My radio stopped working properly after I cranked the car while it was in gear, and my heater unit and headlight switch lights went out too. I think I might have "burned" my radio as a result of a bad voltage regulator, but am not sure. I know that my battery is good, and I have checked all related grounds. I have inspected the fuses, and they seem fine. If any of you can answer any of these questions, I would be very appreciative, as you could save me a lot of money ! How do I go about checking for whether or not I have a clean power supply to the reciever? What is a voltage regulator, and where is it? Can it be replaced? What else could cause such a problem? Thank you in advance for your help.
-Chase-
King of the Twisties, Lord of the Install
Boston Red Sox Fanatic
'94 Calypso Red 325is
Custom ERT Chip, Custom catback Burns Stainless DR-1 Drag Exhaust, 15" OZ Rims with Proxes RA-1s, OMP Strut Tower Brace, Custom ITG Carbon Fiber Cold Air Box/Intake, Unorthodox Racing Power Pulleys, OMP Carbon Fiber Shifter, M3 Front End, JSP Carbon Fiber Wing, Clear Corners.
Old 03-14-2004, 10:12 AM
