Rough idle on 325is after it warms up
Symptons: Idles fine when cold and runs well too.
Starts missing more and more as it warms up
but only at idle, as soon as revs get over 1200 it smooths out.
I suspect a vacuum leak but don't know where to start, or why it only occurs when warm.......EGR maybe??
I've recently replaced plugs, wires, cap-rotor, and adjusted the valves. None of this seemed to help any.
Thanks, Bill
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 04-03-2004, 03:25 PM
camaroman's Avatar
My car has similar trouble, and so did someone else on the board. Your problem may be leaky or dirty fuel injectors; you might want to check those out. As far as the vacuum hoses, just start takin' a peek around the intake manifold....they're in plain enough sight and you're gonna be able to see any signs of failure pretty quick. Start around the throttle area, and work your way around. Good luck.
Mike
Old 04-04-2004, 05:43 PM
