-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Possessed left turn signal... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/156964-possessed-left-turn-signal.html)
HMan66 04-05-2004 09:37 AM
On my '84 318i the left turn signal flashes properly when the hazards are on, but real fast when Im just using the turn signal. To top it off, when the headlights are on, the left signal flashes slow, erratic, and sometimes not at all. The right one seems fine and all the bulbs seem to be working. Anyone have any insight on this?
Jared at Pelican Parts 04-05-2004 09:38 AM
You probably have a burned out bulb somewhere.
HMan66 04-05-2004 09:46 AM
Thats what I thought too at first, but they all seem to be working fine. Ill double check though.
HMan66 04-05-2004 09:47 AM
Could this have anything to do with a burned out driver side high beam??
Jared at Pelican Parts 04-05-2004 09:48 AM
No, works on a different circuit..
How are the bulbs in the istrument panel for each turn signal.. (the green ones)
HMan66 04-05-2004 09:55 AM
Theyre working fine too.
GreyDeemon 04-06-2004 03:15 AM
the problem with mine is the plug for the turn lights. They tend to rust and make the lights erratic. You'll have to take them out from the bumper and clean all conectors. A bit difficult if you don't have a ratchet and an extension, the socket I think is 10mm and one of the nuts holds the bumper rubber in place.
HMan66 04-06-2004 09:34 AM
Ok...I got the signal working...it was the connector at the left front signal just like GreyDeemon said. However, now when I step on the brake, I get no turn signal at all! There must be a crossed wire somewhere because the brake light and turn signal are on seperate circuits. Also, does anyone know where I can see a picture of the fuse box with circuit labels for my '84 318i?
HMan66 04-06-2004 09:35 AM
Oops...when I step on the brake with the headlights on I lose the turn signal....maybe a short in the headlight switch?
