radio code
When I go to put the 5 digit code on the radio I hear a loud beep before I get to the fifth digit. I tried leaving the key on for a few hours,but still I get a beep before I can get the code entered. Any help would be appreciated. Thanks Joe:( :(
Might help if you tell us what year and model it is....
sorry 1993 325i. I tried today but as soon as i hit the 2nd digit it beeps. Thanks Joe
Did it start doing this all of sudden? Have you recently disconnected the battery or done any other work to the car?
The car was in an accident,so the battery went dead from sitting. I called the dealer to get the code punched in the code and it worked fine. I replaced the old battery with a new one and now all I get is a beep when I get to the third or fouth digit.
Hmm, little confused the code worked fine with a dead battery? Or after you replaced the battery..
The radio worked fine,I disconnected the new batery by accident and now I got nothing
Try disconnecting the battery again and wait for a few mins before you re-connect it. Then try the code again.
You could also try starting the engine first incase it's an issue with low power. |
| All times are GMT -8. The time now is 01:27 PM. |
