-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   A/C problem (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/161868-c-problem.html)
jonmatar 05-06-2004 02:22 PM
A/C problem
I noticed that my A/C wasent as cold as it used to be so i put a can of freon in it..I go drive it to see how it did and It is worse than it was before i put the new can in!....not only that now the compresser cycles on and off about every 10-20 secounds which it never did before...anyone know what happend?
thanks.
Jared at Pelican Parts 05-06-2004 02:42 PM
you over filled the system and it is tripping the high pressure switch.
jonmatar 05-06-2004 07:21 PM
So if I let some freon out of the system will this problem just kinda work itself out?
Jared at Pelican Parts 05-07-2004 09:27 AM
Most likely.
