location of External Ambient Air Temp Sensor
Does anyone know where the external ambient air temp sensor is located on a 1990 E30 325i. I want to replace it myself but want to be sure it is easy to get to before I order the part.
Thanks! |
If you are refeering to the sensor for ther outside air temp, it is located in the driver's side brake duct in the front of the car
Can I see it and get to it without the car being on a lift....meaning, laying on the ground?
Should be able to. Look from the front of the car throguh the driver's brake duct. You'll need to remove the duct from the car in order to change the sensor. The duct should just pop out...
| All times are GMT -8. The time now is 03:45 AM. |
