Drive shaft 325es 1987
I have a question I am trying to sort out a few things on the rear end of my car. Its making some noises and has for some time I know I have a bad wheel bearing if not two and need replaced. However I have felt issues I beleive associated with the drive shaft, or maybe the bearing. Anyway any one know how to tell if the drive shaft is going bad ?
thanks
RandyB
Old 06-25-2004, 07:30 AM
Author of "101 Projects"
Wayne 962's Avatar
The driveshafts themselves don't go bad (at least I haven't seen any). The bearing that supports them, and the flex disc can disintegrate. Check out the following articles for inspection and replacement of these components:
http://www.pelicanparts.com/bmw/techarticles/E36-Guibo/E36-Guibo.htm
http://www.pelicanparts.com/bmw/techarticles/E36-Driveshaft_Bearing/E36-Driveshaft_Bearing.htm
-Wayne
Old 06-26-2004, 09:02 PM
Shift into nuetral while driving and see if the noise goes away >>this takes the driveshaft out of the picture
Old 06-27-2004, 07:58 AM
Wayne: Thanks Alot! those articles are awsome. Do you have any part numbers to corrispond with this? Does pelican sell these parts?
BMWcowboy: Yeah I did that and the the one noise in particular goes away. So I guess that answers that question.
thanks again guys!!
Old 06-28-2004, 04:51 AM
