Natygrl259's Avatar
Send a message via AIM to Natygrl259
Question Signals out
My signals are no longer working. I own a 1987 325i bmw. After some looking in the manual my dad told me to ask around for a signal/hazord flasher. I called 3 dealerships close to my home. and the first one gave me a price of 44.10 the next one said 34 dollars but neither of these stores had them in stokc. I am leaving for a road trip soon so I was looking to find one in stock.
The next place I called said they had no clue what i was talking about. The had a relay for 44 dollars but a flasher in my car (1987 325i) didnt make sense. He told me to ask my father if it was the relay and call back. After I called back I recieved a diffrent guy on the phone he set out to look for it and 5 minutes later the both got back on the phone and told me that my car doesn't really use a flasher. And continued with saying that if I was talking about a ford he would no exactly what i ment... but he has worked there for 10 years and really dosnt think that i am correct on this one.
Is this guy correct or does he not know his bwm's? Can anyone confirm that my model has a flasher? And if so do u know what it is more comenly know as?
Old 07-30-2004, 11:36 AM
Natygrl259's Avatar
Anyone ?
Old 07-30-2004, 11:50 AM
ghostnova's Avatar
Well, a flasher is a common part in many cars as far as I know. I had one go out on me in my 1981 320I. Normallythe parts are cheap,but because we have BMWs they double ,triple or even further raise the price.
Old 07-31-2004, 10:02 AM
It should be under the drivers dash area>>small silver box
Old 07-31-2004, 03:57 PM
pipe's Avatar
My god!!
BMW flashers work the next Way (not complete scheme Sure!)
flashers - wires - relay (steering weel column located, remove the bottom plastic cover, its black color with 3 pins for standar cars or 4 pins for cars pulling motorboats or similars) - wires - emergency hazard button.
You have the problem either on the relay or the emergency hazard button which also works as a relay.
check them both (begin with the standar relay, is cheaper).
Good luck
(2X) E30 M40 + E39 M51
Old 08-05-2004, 02:42 AM
