-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   funny gauge problem - they all failed at once! (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/172360-funny-gauge-problem-they-all-failed-once.html)
wludavid 07-14-2004 06:12 AM
I had finally started feeling pretty confident in my e30's reliability, so I was driving somewhere for work on monday that was about 2 hours away. I was almost there when I drove over some railroad tracks going a little faster than I should have. Just as I got to the other side of the tracks, I notice my tachometer dropping. Thinking my car had died, I pushed on the gas and was a little surprised to feel it surge. Then I noticed that my fuel, coolant, and mileage gauges had also dropped to their "off" positions. And since my odometer had already stopped working, I had to chuckle. The only things functioning on my gauge cluster right now are the speedometer and the ABS light which has been on for months (which incidently, I need to have repaired before it can pass inspection in Virginia, so I guess I'll take it apart and fix it all at once).
I suspect the jar from the railroad tracks knocked loose the common ground to the cluster, so they all failed at once, but I wanted to post to see if anyone else has run into this problem.
Jared at Pelican Parts 07-14-2004 09:14 AM
I would suspect the same, the bump may have knocked something loose.
wludavid 07-18-2004 11:58 AM
I was inspired to check the fuse panel the other day, and it turns out that I had blown my #10 fuse. The gauges seem to be the onlu thing really affected, but I haven't done too much searching. Maybe the backup lights are dead too...
So I replaced my #10 fuse - I stared with a 5-amp fuse and it worked for a second, then blew. So I went up to 7.5- and 10-amp fuses (it's supposed to be a 7.5-amp fuse) and the same thing happened.
It seems like there is a short somewhere in the circuit that's allowing too much current to be drawn. #10 is on a big circuit though. Any ideas?
Rich911E 07-27-2004 04:10 PM
First, check the instrument cluster ground. But I had almost the same problem (all the gauges went except the speedo) and it turned out to be the SI (Service Indicator) board. It is not a big deal to change -- about an hour or two. You can get it out without removing the steering wheel if you have an airbag car.
Rich
pipe 08-05-2004 02:49 AM
There's another way.
You have a shortcut for sure, the problem is WHERE AND OR WHY
you can do the next to locate the problem (although not much recommended) use a 30A fuse and wait until smoke comes from somewhere.
