Timing plug removed by error, Question
93 325i with 100,000 miles
The water pump went (old plastic impeller type) so I replaced it. When draining the antifreeze I mistakenly remove the primary timing chain tension cover plug. I thought it was the antifreeze engine block drain. I put the plug and spring right back when I realized it was not for the coolant. Nothing was moved on the engine. Do I have anything to be worried about?????? Thanks for any advise. |
As long as you got the tensioner back in correctly >>slot going sideways>>then everythings good~:)
| All times are GMT -8. The time now is 12:48 AM. |
