Rough Idle / No codes
Lately I've noticed a rough Idle (like a miss) when I start the car. Seems to happen mostly when I turn on the A.C.. It will continue until I get to about 1500- 2000 rpm. It also happens in gear. I ran the codes and all I get is 1444.
Idle Control Valve is where I think I will start. Maybe it is gummed up and needs cleaning. Do they operated like a Porsche ICV with a plunger type actuator? Also thought coil pack, but it runs great after reaching 2000rpm. I will check vacuum hoses also. What do you guys think? let me know if you need more info. Thanks |
Jeff:
The ICV operates just about the same as the 911, but the Porsche one is MUCH easier to get at. Tim |
bump.
| All times are GMT -8. The time now is 02:55 PM. |
