Unhappy noisy engine 87 325i
I have a 87 325i convertible. When the engine revs, even a little, there is a rough noise that suddenly appears and stops when the revs drop. It sounds like a bearing of some sort that works intermittantly, rpm dependent. I have had 2 experienced mechanics look at it briefly, one said it was the fan clutch.. I doubted this as it was replaced about 6k miles ago. The other said it was the housing around the distributor..I don't think so. It is getting worse, and I can't localize it. It is perhaps worse on the left side of the engine. Any ideas?? Thanks.
Old 08-11-2004, 06:18 PM
Did you just have the water-pump or timing belt replaced???
Old 08-12-2004, 05:44 PM
No, but I think the timing belt is due. It's been about 50,000 mi but also about 6 years. No water pump work done ,at least in last 2 years that I have owned it. Thanks
Old 08-13-2004, 11:05 AM
Very common in the above repairs to get the plates back on correctly->>if they are wrong they will make noise->>but if no repairs have been done then I would look elsewhere
Old 08-14-2004, 09:49 AM
