BMW Roundel 320i headlights inop
Hey all,
First time post here and need some help. I purchased a 1994 320i euro spec BMW. It has 135000 km on it. My problem is my headlights are out. The high beams and daytime lights work but not the regular headlights. Both sides are out. I have checked the fuses and bulbs (even put new ones in to check) with no luck. Anyone have an idea where to check next?
Old 08-26-2004, 10:05 AM
Check the relay in position 6 in the fuse box. It's in the middle row of relays, the third one back from the front of the car.
Old 08-26-2004, 10:39 AM
thanks funkymarcus.....I'll check it out ......do you know if any of the other relays can be swapped into that position to test it?
Old 08-26-2004, 11:25 AM
