Question lamp
hi can some one help with this some times when i start the car
i get a picture of a car and a lamp showing on the right hand
side on the dash board. after you drive a bit it will go out.
many thanks
Old 09-04-2004, 03:43 AM
RS1060's Avatar
I thought that the owner's manual in each car would show what each symbol represents. Try that. If you don't have one reply back and I'll check mine.
Old 09-04-2004, 11:45 AM
mankiks323i00's Avatar
it means a bulb is burnt out on that side of the car. if it comes on and off it may be a loose bulb or its defective replace suspect bulb with new one and same wattage.
Old 09-07-2004, 02:59 PM
