Knock Sensor
525I(A)11/1995.
HELP!! I understand the knock sensor (cyl.4-6) is located in front of the engine. Accessible after removing the top engine cover. Gosh ! I can't locate it . This is my first time. I hope you understand. Thanks.:confused: :confused: |
On E36 six cylinders it is under the intake manifold bolted to the block. The intake manifold needs to be reomved per Bentley. You really need a Bentley repair manual if you plan to do any DIY repairs.
| All times are GMT -8. The time now is 06:22 PM. |
