-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   96 computer test list? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/186605-96-computer-test-list.html)
Thurmer85 10-11-2004 08:34 AM
i have a 96 328i and if i hold the 10 and 1000 buttons a test screen comes up and asks you for a number 1-29 i tried them all and a couple do different things but only a couple worked most didnt i was wondering if anyone knows what each one is for or if there is a list somewhere thanks
Stephen 325TDS 10-11-2004 10:07 AM
Thurmer85, have a look below.
Stephen
Test numbers for E36 OBC
1 Display Test .. all LCDs and LEDs activate 2 Current Consumption in l/100km
3 Current Consumption in L/hour
4 Average Consumption (used to calc. Range) 5 Current Range
6 Not used ..
7 Average Fuel in Tank (l)
8 Current Speed (km/h)
9 System Voltage at terminal R
10 Country/Language
11 Units/ AM.PM
12 Average Speed (km/h) for calc. ETA
13 ETA
14 Date of software/mask of OBC
15 Production Diagnosis (??)
16 Production Diagnosis (??)
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous v. intermittent) 19 LOCK/UNLOCK all functions
20 Correction Factor for OBC Fuel Consumption (SEE BELOW!) 21 Reset all defect codes, date and time ... activate by pressing SET/RES
Note: #20 the factor is used to correct the OBC Avg Fuel Consumption figure to reality .. if your OBC is off a bit ... fill UP totally ... run tank down and refill ... calculate your Actual MPG ..
Now enter test 20 get the old Correction Factor .. NEW CF = OLD CF *(Actual MPG/OBC MPG)
enter the NEW CF using the numeric kays and hit SET/RES to store ..
PLEASE record you OLD CF so that IF you screw up you can always go back to what it was .."
kocio67 10-11-2004 10:59 AM
Stephen 325TDS,
What about HVAC test menu on newer digital climate control?
Stephen 325TDS 10-11-2004 01:20 PM
kocio67, sorry, don't know.
Stephen
Thurmer85 10-13-2004 05:55 AM
Thanks for the list that was very helpful
Stephen 325TDS 10-13-2004 11:03 AM
No problem. Glad to help.
Stephen
Jared at Pelican Parts 10-13-2004 03:36 PM
cool feature. I didnt even know about this...
