tabascobobcat's Avatar
Question Hard to Start after Rain / Wash
We have a '95 325ic w/ 100.000 miles. Recently it has become hard to start after driving in the rain or a good wash. It cranks srong and free but doesn't fire. It acted the same all 3 times it has occurred. Crank (on and off, not continuously) it for 5 - 7 minutes, and it fires without even a stumble and runs fine again until the next run in with water. Looking for advice to help short cut the analysis process. Nothing obviously wrong under the hood. Plastic cover is still installed. I did however recently replace the valve cover gasket and plugs. Looking for advice and opinions. Thanks. Dave
Old 09-29-2004, 03:54 PM
LeRoux Strydom's Avatar
You may have a water leak in the DME compartment, it is a common problem. Search this forum for "wet DME". You'll find detailed descriptions on how to open up the DME compartment, seal the DME after drying it out and cleaning the connectors, as well as a permanent fix to the water drainage design flaw.
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 09-30-2004, 02:04 AM
Thanks for the advice. You were right on the mark. Drain hole was plugged, and the DME cover has deteriorated. I have some water proofing to do.
2005 Acura 3.2 TL 148,000 miles
1988 911 Cabrio 104,xxx miles
1965 Honda Super Cub 50 1442 miles
2008 Honda Odyssey 105,000 miles
GruppeB #0202
Old 09-30-2004, 06:42 PM
Ad Hoc's Avatar
You're fortunate to have caught it early. The design and location of the DME compartment on an early to mid 90's E36 was a recipe for disaster - I paid the ultimate price: My DME got completely fried.
This Pelican article is great: http://www.pelicanparts.com/bmw/techarticles/E36-DME-Repair/E36-DME-Repair.htm
I've personally used plastic bags and waterproof silicone roofing caulk to waterproof mine.
Bottom line for me is I don't go through car washes. They dump 50+ gallons on your car. Even with all the precautions I've done to my DME and its compartment, I still wash by hand
Old 10-08-2004, 11:53 AM
Handwashing is a must for my cars too. I must use too much water. Now if a drove a Chevy...........
GruppeB #0202
Old 10-10-2004, 10:46 AM
