Want to change trans fluid...
I want to change my trans fluid for my getrag 260 and put some redline in, I can't seem to find any trans plugs/washers that i'll need to replace when I do this. I'm going to replace my differential fluid too, I found a new plug for it, is that all i'll need? Obviously never done this before, so take it easy :p
You dont need to replace the plugs unless they are damaged. There are also no sealing rings, the plugs thread into the transmission. You will need a 17mm hex key or socket to remove them.
I'm sorry for posting, I couldn't find my Bently manual. I just looked it up an noticed that, thanks for the reply.
no need to apologize, thats why the board is here....
dif
I apolagized because it was a waste of your bandwith :)
and what about my LSD? It just threads like the trans, no sealing rings? |
Actually, no, the plugs on the diff use sealing rings.
33 12 1 212 461
33 13 1 214 100 ? |
| All times are GMT -8. The time now is 07:50 AM. |
