-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Block heater install (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/187968-block-heater-install.html)
Jeron 10-19-2004 08:17 AM
How can I add a block heater to my 1997 M3?
I think the issue is that BMW's dont have coolant plugs on the block.
I would like to tap my aftermarket aluminum thermostat housing and put it there, if that is feasable.
Jared at Pelican Parts 10-19-2004 08:18 AM
IS it cold enough in Texas to warrant a block heater?
Jeron 10-19-2004 08:25 AM
That was a super quick response :-)
My drive to work is only about 15 min and it takes 10 min to get the oil over 120 degrees in the summer. I imagine that I will have to baby the car all the way to work with the temp below 50.
I'm willing to go to resonable effort and expense to achieve a fun drive to work. (Driving home will still suck;)
Jared at Pelican Parts 10-19-2004 08:27 AM
im not sure a block heater would heat up fast enough to help you out...
Jeron 10-19-2004 09:58 AM
Maybe I'm asking for the wrong thing.
I want to install a heater element on the car such that I can plug it in to a timed electric source. The timer will come on a few hours before I leave in the morning so that the coolant and therefore the engine is warm when I first start it in the morning.
Jared at Pelican Parts 10-19-2004 10:01 AM
Ah, ok, I see... hmm.. lemme look into what we have... Probably something we'd have to get from BMW...
Jeron 10-19-2004 10:12 AM
Just remembered to do a search on my TIS and found BMW parts 82 12 1 466 507 & 82 12 1 466 508. But these parts are for other models and the document is from 1983.
Jared at Pelican Parts 10-19-2004 10:15 AM
Just talked to my contact at BMW, he says there is nothing available stock to use on your car. He said that if it had freeze plugs, then you could use te factory one...
Jeron 10-19-2004 10:22 AM
I thought that was the case.
I wonder if I could tap the aluminum thermostat housing I just bought and screw in a block heater.
The problem is that the thermosat housing is outside the engine coolant loop and it is at the top of the radiator. So (1) I would be heating the radiator coolant, not the coolant in the block. And (2) since heat rises it might not be very efficient. Although I suppose since Im heating liquid rather than air it might still work well.
Jared at Pelican Parts 10-19-2004 10:25 AM
Unfortunatley, where the freeze plugs would normally be is the most ideal location. You could always tap into a water jacket, but what would be the point?
Jeron 10-19-2004 10:47 AM
There are areas in the world where block heaters are absolutely necessary. I'm sure people drive BMW's in those areas so there must be a solution. I may endup calling dealers in Canada.
Jared at Pelican Parts 10-19-2004 11:24 AM
I called a dealer in Canada, they said no block heater was availble
Tim Polzin 10-19-2004 12:16 PM
OK, this thread just reminded me that I need one too.
I just called the dealer in Edmonton and they said they had one in stock for my 318i. The BMW part number is 12810304876 and cost $43.50.
I forgot to ask about a 97 M3 though. Their number is 780-484-0000 (Bavaria Motors) if you want to call yourself.
Tim
Jared at Pelican Parts 10-19-2004 01:04 PM
I did more research on this and found there is no provision on the M3 for a block heater. You'd need freeze plugs in order to install it, and the M3 doesnt have them.
Jeron 10-19-2004 01:23 PM
I was under the impression that the engine did not have a coolant drain plug, which apparently it does. Hopefully, I can find a generic block heater to fit this drain plug.
Jared at Pelican Parts 10-19-2004 01:30 PM
thats not a bad idea...
Jeron 10-19-2004 01:32 PM
So far I've only found freeze plug heaters and dip stick heaters. Apparently dip stick heaters are temporary and must be swaped out before starting the engine, so that sucks.
Tim Polzin 10-19-2004 01:44 PM
A quick 101 on block heaters.
They come in several different types
The one Jared is refering to is mounted in holes that are used during casting of the engine block. Normally, the disk used to fill the casting hole (sometimes called freeze plugs because on early engines, if the cooling water would freeze, it would force out the casting plug) would be removed and a new one installed with a heating element (that looks a little like the one used in a hot water heater).
Another type is one that mounts in the lower rad hose. It is basically a small cylinder with a heating element and circulates the heated coolant through convection.
Another type is attached to the outside of the sump (often by a big magnet) or plugs into the dipstick hole and and heats the oil.
The first is the most common and is the type usually installed by the dealer. The second is often installed after market because it is easier to do but may not be as effective. The third type is more of a temporary fix more often used on tractors or in emergency situations. The dipstick heaters do not work all that well.
There may be others but these three are the most common. None that I know of are small enough to fit in a drain plug.
Up in this country, we take our block heaters (and beer) seriously.
Tim
Dave at Pelican Parts 10-20-2004 08:37 AM
AFAIK, all of these are intended solely to keep the engine oil from getting thick enough to cause difficulty starting. They would be used to warm up the oil sump to a temperature above freezing (32F), but probably still something cool to the touch. Your engine oil's normal operating temperature is 180F-220F. You will not find anything that will warm up your oil that far. I don't know Texas winters very well, but depending on how cold it gets overnight you may find that the block heater only raises the temperature of the oil by a few degrees F...
I don't think there is any shortcut to warming up the engine.
--DD
Jared at Pelican Parts 10-20-2004 08:39 AM
Thats what im thinking as well....
Jeron 10-20-2004 10:21 AM
Some block heaters heat the oil dierectly but most heat the coolant and therefore passively heat the oil.
I think the coolant block heaters can get to well over 140 degrees, depending on conditions and size. Some come with switches to keep the temp from getting too hot.
Apparently the drain plug idea is a no go because most heaters are too large and hence use the freeze plug area. I've found some magnetic type heaters and also some lower heater hose types. The lower hose type seems the most feasible.
KNS 10-21-2004 03:15 PM
I used to use a magnetic type oil sump heater on my old Honda. My drive to work is less than ten minutes and the temps will drop down into the teens and twenties here in the winter. Prior to driving off I could pull the dipstick and feel that the oil was indeed warmed up. It was worth it for such a short drive.
Jared at Pelican Parts 10-21-2004 03:16 PM
Where would you put it on the M3, seems like there isnt a lot of free space...
Tim Polzin 10-21-2004 05:37 PM
Just for reference sake, here is the heater I picked up for the 318:
http://forums.pelicanparts.com/uploa...1098408750.jpg http://forums.pelicanparts.com/uploa...1098408773.jpg
And this is the instruction sheet that came with it. The numbers seem to have been updated though:
http://forums.pelicanparts.com/uploa...1098408868.jpg
There is no thermostat on this heater, so depending on the ambient temp, the engine can get warm enough to use the interior heater nearly immediately. I'm not sure about the rad/heater hose types.
Tim
